Creating Materials through GDL objects with known RGB values
The GDL reference book refers to creating materials through GDL scripting however I can't find where it mention what format the RGB values are in other than values between 1 and 0 for each RGB value. Has anyone had experience creating materials using RGB as Actual Value, 8-bit (the usual 255 color system) or as a percentage?
1 REPLY 1
It's easy.
0.5 = 50% (or about 127 in the 8bit equivalent)
Just do the arithmetic.
