2008-04-28 02:32 PM
2008-05-10 03:43 PM
Bier wrote:Hi Bier.
Having only looked at the demo's, (which not all seem to work right), I do think Objective may be an option I would look at. Looks like a good product but maybe a bit more mellow
in the ad's Ralph?
2008-05-13 06:19 PM
Djordje wrote:I've been experimenting with mouldings with the wall profiles, but they sometimes seem to snap to the existing walls and make weird little glitches. If I put them on a new layer will that solve the problem? What do you mean by non-intersecting layers?
Don't forget to put the moulding walls on an non-intersecting layer!
2008-05-13 07:24 PM
Simon wrote:There is a number by the layer name. Elements -walls in this case - on the layers with the same number intersect, with the different numbers don't.Djordje wrote:I've been experimenting with mouldings with the wall profiles, but they sometimes seem to snap to the existing walls and make weird little glitches. If I put them on a new layer will that solve the problem? What do you mean by non-intersecting layers?
thanks
