Creating a BOX in GDL
I'm learning GDL and practicing to create a rectangular by writing code.
The script was reported ok but it's not showing any lines.
Does any one know the reason ?
By the way, where is the best resource to learn GDL? I've been following the GDL help/tutorial in ArchiCAD but would like to have more material to learn.
Please advise
Many thanks
7 REPLIES 7
Dennis Lee
The greatest resource that I know is GDL cookbook. http://www.nottingham.ac.uk/sbe/cookbook/
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
Rod Jurich
Second that!
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
tranthainguyen!
You should send or attach the script that you wrote.
Without the script we can't to help you.
There is an other professional book: http://www.cadimagetools.com/gdlbook.aspx
Best regards,
David Maudlin
tranthainguyen wrote:
I'm learning GDL and practicing to create a rectangular by writing code. The script was reported ok but it's not showing any lines. Does any one know the reason ?
Tran:
You can place a 3D statement in the 2D Script (like Rect a, b), and ArchiCAD will say the script is OK, but no shape will be created. Be sure that you are using 2D Shapes in the 2D Script.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Hi David,
Thanks for your tip. I keep an eye on this to check
And thanks all
vistasp
The cookbook (v.4) is downloadable as a PDF here.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
By the way, you should download both versions (3.1 and 4.0) as 4.0 doesn't actually cover all the topics that 3.1 does, but it does have information on some of the newer GDL features.
