‎2009-01-19
03:25 AM
‎2023-05-24
12:41 PM
Rubia Torres
‎2009-01-20 01:02 AM
‎2009-01-20 01:45 AM
richard wrote:Very odd about the 1086. Hotfixes are cumulative and do not have to be installed in order, except for one hotfix for 11 that violate this otherwise constant rule. The current build of 11 is 1210, but hotfix 1200 has to be installed first (if I am remembering the issue). So, just skip 1086, and download 1200 and see if that will install. Then apply 1210. You can use Check for Updates, or just go here:
AC11 updating... you are on to something here.
Have downloaded hotfixes and installed up to 1040.
Hotfix 1086 will not install - and gives me an error and advises to look
‎2009-01-20 01:52 AM
‎2009-01-20 01:54 AM
‎2009-01-20 05:50 AM
‎2009-01-20 06:58 AM
richard wrote:Yes - the end of my last message. Checkscript ran fine. No problems.
Again I must thank you for the time you have spent answering the questions - have you managed to get that object of mine to check script ok?
‎2009-01-20 10:20 AM
‎2009-01-20 06:45 PM
‎2009-01-21 01:11 AM
richard wrote:Please re-read my message. I did not modify the scripts - so there is nothing to post. I simply defined the 'missing' materials. The script is 100% fine. You should just follow Olivier's steps to make it material-parametric.
Would you mind attaching the file you have corrected so I can download and see what scripts you changed please?
