Creation of New Doors
Hello!
I am looking to create two new doors for our company. We frequently use sliding doors with 5 or 6 panels. There is no archicad door by default that meets our requirements, but I believe I understand enough GDL now to modify a door to do what I want. My only problem is, when I place an Archicad door that I want to modify and then 'open' that object, there is no script in the 2D or 3D as there was for other objects.
So my question: Where can I find the 3D script for Archicad doors?
1 REPLY 1
In the master script they will CALL another object (macro).
That macro will CALL other macros and they will CALL even more.
If you can unravel how a GS scripted door or window works you are doing very well.
Trying to isolate the bit you need can sometimes be very tricky.
Good luck.
