alemanda
Custom CW frame scripting
I made my own custom CW frame. Script.
I used the cprism function but I'm sure that I have to use the sprism{2}.
In fact when I make a CW along a polyline my transoms are not cut properly at the extremities.
My problem is how to define the "tangle" and "bangle" parameter for sprism{2}.
Among the parameters for the CW there is AC_clampvector and AC_topconnplane and AC_bottomconnplane ...
Does anybody have experience with that?
Thanks
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
3 Replies 3
alemanda
...and these are the parameters I've mentioned before
Regards
AC27 latest hotfix
Win 11 Pro 64bit
What Frame Intersection Priority numbers are set for these Frames?
I would set the vertical one to something (e.g. 10) and then set it for the two horizontal ones to some lower value (like 9 or less).
This works with normal Frames but I am not sure it also works with custom frames. You need to check.
alemanda
The priorities are set well. This was my first doubt ...
I save a curtain wall as GDL.
Reading the code of the element (transoms and mullions) I saw that the SPRISM{2} is used.
One of the parameter to be passed to the SPRISM{2} is the top angle and bottom angle.
When you write a script for a custom frame part (mullion or transom) these parameters can be passed by archicad to the custom element.
The problem is that I couldn't understand which of the parameters highlighted before is the right one ...
Moreover also the priorities are regulated by one of the parameters listed above ...
I tried to read the code of the "profile 13" listed among the "custom" frame profiles ... but it's impossible to read that code ... it's not an usual GDL object ...
AC27 latest hotfix
Win 11 Pro 64bit
