muddasick wrote:
I have a very elaborate rail that I made using slabs and saved it as an object. I want it to follow a circular pattern. Is it possible for me to give the railing a radius?
you're talking about the cross sectional shape of the handrail right? there are many ways of achieving what you want relatively quickly. a couple of things spring to mind:
1. use the 'profiler' tool - simply draw your shape as a fill, select it and activate the profiler. (a quick read of the manual might be helpful before you begin). this is probably the simplest way but a 'static' solution: you will not be able to easily change the radius of the rail without generating the whole thing again
but you can make the railing follow a complex path pretty quickly.
2. drag and drop the fill into one of the GDL window - archiCAD generates the code for the polygon. you then need to modify that code to fit into the syntax of the GDL solid that best suits your needs . . . more complex and requires more explanation than i've given, but i'm not at my laptop right now (net cafe) so i don't want to start giving more detailed advice without being able to check that i'm heading in the right direction myself.
you could always e-mail me the profile/path or both with a quick description of what you want and i'll see what i can do . . . (e-mail address is in my signature)
HTH
~/archiben
b e n f r o s t
