Eric Graas
Custom Component issues
I am trying to create a custom door slab. I create slabs on the floor plan, select them, and go to file/libraries and objects/save custom component... When the menu comes up, the only option is custom window panel. I need a door so it can be shown with opening swing. Has anyone had this issue before?
I would suggest you try a search first : Search > "custom component"..... and you'll find your answer on the first page...
