Custom Door Panel Not Showing
Scott Bulmer
I have created a custom door leaf using slabs and complex profiles. The door size matches that specified in the Door Settings Dialog Box. I have saved via Save Custom Component as a Custom Door Leaf Subtype. The part appears in the Custom Panel Name of the Door Settings DB, however only an outline of the door appears wire frame. Please see attachment. Any thoughts will be appreciated. Thanks, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
ztaskai
I've never seen a problem like this before.
You have a pretty clear description of the case here. I think you should send a PLA of the concerned parts to GS Technical Support with your text. I don't know a way to post a PLA here, it could help here, too.
Regs,
Zsolt TƔskai
ArchiCAD Development - GDL Team
AC13, AC14 and upwards...
Chris Grantham
has anyone figured this out? I can't seem to.
16" MacBook Pro M1 Max
Mac OS 26
ArchiCAD 27 Build 6010
