I have created a custom door leaf using slabs and complex profiles. The door size matches that specified in the Door Settings Dialog Box. I have saved via Save Custom Component as a Custom Door Leaf Subtype. The part appears in the Custom Panel Name of the Door Settings DB, however only an outline of the door appears wire frame. Please see attachment. Any thoughts will be appreciated. Thanks, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
