Custom Door Panel
Hi all.
I'm having some problems creating and using a custom door panel. i've followed the step by step guide for creating the panels and have run into these problems:
1. the panel is not automatically loaded into the custom panel name option box as the help topic says. the library has to be reloaded before it appears... though not a major problem.
2. once loaded, if i try to use the panel the following error message appears
"Invalid transformation matrix (singular) at line 10 in the 3D script of the file bifoldpanel.gsm"
i've opened the object and used the 'check script' button but it says the script is ok....
does anyone have any suggestions as to where i might be going wrong?
cheers
nick
1 REPLY 1
hi again,
just thought i'd add that the very same object works just fine when saved as a custom window panel...not sure whats going on there
Nick
