Learn more
ArcAngel
Custom Door Panel
I cannot create a custom door panel in ACAD V9 - I know how to do it - but the "CUSTOM PANEL" box does not APPEAR in the dialogue window.
I downloaded the latest 9 Library.PLA today but that didn't solve the problem.
I even went back to V8.1 but it didn't show there either.
Carlo
AC4.5 - AC 25 (User since 1992)
9 Replies 9
Are you looking for a 2D symbol of your custom door? I have never seen one either. I select the custom door panel option and then type in the name in the door panel type. You do have to remember the exact name that you saved it as though.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
TomWaltz
Which door object are you trying to place the custom panel in?
Tom Waltz
ArcAngel
I'm trying to insert it in the basic D1 (interior wood/metal), although I've tried everything - including a garage door!
The custom panel option just ain't there (see screenhot)
AA
Carlo
Try the SE library. I don't think the custom option has ever been in the standard AC9 library? But I might be wrong.
ArcAngel
None of the tutorials mention the SE library and the one from Iron Insights is based on the 8.1 library. See: http://www.graphisoft.com/community/envisions/03.11.jtburk.html
Carlo
TomWaltz
It is. I still use the standard library and use custom panels all the time.
I cannot say about the original library AC9 came with, though, which I know did have some different things in it.
Tom Waltz
How strange? The standard AC9 library that I have doesn't have any custom panel options? Maybe just the US version has them...
Petros Ioannou
AFAIK it is only available in the US AC9 library
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
ArcAngel
Petros
Is there a macro that can be copied into the International Library?
Carlo
Carlo
