tanyalipton
Custom Door no Save Selection AC21
Just updated to AC21, cannot find the save selection as (door/window) in the File/Libraries and Objects menu. Please advise asap...?
Thanks in advance.
Tanya
3 Replies 3
Are you in plan view with your door flat on the 'ground'? Menu is there - as shown in attached...
furtonb
If it's still not there, switch back to the standard work environment, and see if it shows.
odv.hu | actively using: AC27-29 INT/HUN - multiple builds | Rhino6-8 latest build | macOS @ apple silicon / win10 x64
Do You have the Default library loaded?
Piotr
