Jeff Galbraith
Modules, Symbols and Repeating Elements
Our firm is test-driving ArchiCAD to see if we want to make the switch and we are running a pilot project. We are trying to figure out how to create re-usable objects at large and small scales, such that modifying one will modify all instances of the same object, or symbol. I have found some old posts from several years ago that suggest this must be done using separate files known as modules, however it is important that we be able to work on these symbols within the main project file so we can see them in context of what is around them. Has ArchiCAD evolved in this area yet to allow this? Seems like pretty basic functionality.
Thanks
Jeff
Jeff G
Archicad 27 USA (full), Macbook Pro (16-inch 2023, M3 MAX, 128 GB RAM)
Dave Seabury
Jeff
Not sure what your "reusable object is" but in Archicad you can create 2D and 3D object that when changed will update all placed elements. Hot Link Modules will do the same think but are larger scale, think hotel room that is linked multiple times to create the model.
What is the reusable object that you are trying to create?
David
AC 19-26 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
