Custom GDL objects for FREE
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2009-10-18 02:34 PM
The ArchiCAD object will be available on the website
Send your request via the contact form (
Leave your e-mail address for any communications about the object.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-10-18 06:52 PM
Very generous Master Script.
lec
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-10-22 10:16 AM
Very good to know it.
Can you look on my request with hole labeling? see at link
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-10-22 12:39 PM
Thanks for your entry. At the end of the month I will decide which object I am going to make.
BTW what do you use for your opening? I need them to get the right parameters.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-10-22 01:14 PM
for holes in wall i use windows > openings > W round openings or W rectangular openings. I little modificed them, they drawing the special symbol on plan. For information using element label.
In label is presented WH and level of center of round hole and bottom of rectangular hole with entered text "alt."
In general we missing the hole symbol and label.
the expl. see
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-10-30 09:04 PM
He has asked for a standard size shipping container with standard dimensions. He has send me drawings of a sea container.
PHSantos, I have a few questions:
-can you post a picture of such a container.
-what are you planning to use the container for? Do you wish to use it only for exterior views (3D or elevations) or also on sections?
-How detailed do you want it to be? I don't think you need every bold and screw, that won't be realistic?
-the sea container you have send me has the dimensions (width x length x height) 8' x 40' x 9'6". Is this the only size?
Meanwhile you can all post new requests for next month free custom objects here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-10-31 12:18 PM
Thank you mate!...I really appreciate your generous offer!
The thing is... I've been doing some research, and I found that there's a lot of architects making pretty good projects using it as a kind of "lego" blocks.
In the picture you can see a single container, a standard dimensions table, as well as a small example of what can be done with this amazing modular structure.
So... IMO, the object would have this parameters:
01. Length standard dimension (2d/3d editable hotspots);
02. Angle Doors opening (2d/3d editable hotspots);
03. On/off Doors (2d/3d editable hotspots);
04. On/off Right wall (2d/3d editable hotspots);
05. On/off Left wall (2d/3d editable hotspots);
06. On/off Rear wall (2d/3d editable hotspots);
07. On/off Roof (2d/3d editable hotspots);
08. On/off Floor (2d/3d editable hotspots);
09. On/off Hardware, namely door pivots and lock;
09. Material Doors (Interior/Exterior);
10. Material Right wall (Interior/Exterior);
11. Material Left wall (Interior/Exterior);
12. Material Rear wall (Interior/Exterior);
13. Material Roof (Interior/Exterior);
14. Material Floor (Interior/Exterior);
Regarding the level of detail:
- It doesn't need to represent bold and screws, just the main geometry;
- It would be viewed in 3d/2d/Sections as well in schedules;
- It have to represent all the structural columns and beams;
- Edges may all be sharp;
- The corrugated sheet may appear only in small scales;
- Beams and columns may be hollowed only in small scales;
It also would be:
- A single object with no macros;
- Scale sensitive;
- FPCP (Floor Plan Cut Plan) sensitive;
- Imperial/Metric sensitive;
Ok... I guess its a good start.
Once again, thank you for your great offer!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-10-31 01:33 PM
Any way, I got some good ideas how to take on this project, I will keep you posted.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-10-31 04:19 PM
Master wrote:
Now I see your list of parameters, I can understand why you call it a generous offer
And I was just warming up.
Now seriously... If you need any help you can count on me.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-11-02 11:20 PM
But I got some good progress doing the trapezoid and corners.
Braze, do you have some more details about the doors and the locks? Another 2D file or description would nice.
