2024-01-15 10:05 PM
Is there a way to clean up the elevation and section views of custom library parts? We use a lot of objects provided by the companies of plumbing fixtures and appliances. When I create a new object I can clean up the plan view, but the 3d elevation/section view is always a mess with way too many lines. Is there anyway to clean this up, like I can do to the plan?
2024-01-16 02:13 AM
You would need to optimise or rebuild the 3D, so not really... A lot of these manufacturer objects are also just Revit or 3ds conversions, so are just lots of VERT commands which are impossible to work with...
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 5900X | 32GB | GTX2080TI |
2024-01-16 02:30 AM
As Ling said, you need to optimise the 3D script - which is not easy to do.
However you can convert the object to a Morph.
Edit hide lines, reduce polygons, etc.
Then re-save as an object.
Still not always easy to do, but it is free.
If you want to pay for something that might help, then look at Modelport ... https://archvista.com/modelport/
I can't say if it is any good as I don't use it.
You can download a free demo.
