2024-01-15
01:11 AM
- last edited on
2024-01-15
08:16 AM
by
Noemi Balogh
I upgraded to Archicad 27 from 23. I placed a door on my drawing; now when I go to the library to select a door the on placed on the plans is the only one visible. I cannot select a different door. I am trying to add a garage door.
Solved! Go to Solution.
2024-01-15 02:07 AM - edited 2024-01-15 02:07 AM
Click on the thin grey bar on the left side of the window? Your UI is collapsed by default in A27?
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2024-01-15 01:16 AM
Hi @martica,
You can try to reload your 27 library objects, see this link:
2024-01-15 01:18 AM
Do you have the 27 library loaded?
If you file originates from 23, then you may also need to load the migration libraries.
If that does not help, can you post a screen shot of the door settings dialogue so we can see what you can see.
01:29 AM
- last edited on
2024-01-16
10:40 PM
by
Thank you for your response. Enclosed is the screen shot. Typically when I go to the door tool there are a variety of doors to choose from. In this case only one. The one I used last. I wonder if I did something with the "create container", which I know nothing about.
2024-01-15
01:38 AM
- last edited on
2024-01-16
10:41 PM
by
Hi Mahmoud Qenawi,
I reloaded the libraries, and still can only access one door. To help explain please refer to the screen shot.
2024-01-15 02:16 AM
Hi, I am trying to click on thin grey bar with no results.
2024-01-15 02:17 AM
You were right!! I kept on trying. Thank you🙂
2024-01-15 01:10 PM
I'm so sorry Martica for not seeing your replies on time.
It's great you could solve your case, thanks to @Lingwisyer.
