โ2008-01-18 01:15 AM
โ2008-01-18 01:18 AM
adytc wrote:1. First I've created a slab and label it with the ID "Wallniche".
Hello everybody.
I'm trying to create a niche with a custom shape. I've followed the instructions in AC10 Reference Guide (page 187), but the result isn't the expected one (all I've achieved is a rectangular nieche).
I will describe in a few words what I've done (using some attached print screens), hoping that someone could help me.
Thank you
So ... here it goes:
โ2008-01-18 01:19 AM
adytc wrote:2. Then I've saved it as a window.adytc wrote:1. First I've created a slab and label it with the ID "Wallniche".
Hello everybody.
Thank you
โ2008-01-18 01:22 AM
adytc wrote:3. When placing the new created window into a wall, the hole doesn't have the desired shape.adytc wrote:2. Then I've saved it as a window.adytc wrote:1. First I've created a slab and label it with the ID "Wallniche".
Hello everybody.
Thank you
โ2008-01-18 01:27 AM
adytc wrote:4. And one last question: how can I make the custom niche display correctly in floor plan? (how can I get rid of those 2 lines?)adytc wrote:3. When placing the new created window into a wall, the hole doesn't have the desired shape.adytc wrote:2. Then I've saved it as a window.
โ2008-01-18 03:47 AM
โ2008-01-18 07:20 AM
Peter wrote:Hi Peter.
I tried the following to test "custom wallniche creation".
I drew one slab with the shape and thickness I wanted
for the back wall of the niche and made it's underside elevation
equal to the depth of the niche. I then copied this slab and pasted
into the plan in the same place as the first slab. I selected one
of the slabs and changed it's ID to wallhole and opened
the 3D window and saved as a window.
The 3D view of the niche looked fine but in 2D it was not correct.
I found I had to set wall contours to "None", open the part
for editing and draw in the 2D symbol window the lines and fills
I wanted to make the 2D symbol look the way I wanted.
Peter Devlin
โ2008-01-18 07:50 AM
โ2008-01-18 02:09 PM
Barry wrote:Hi Barry.
Try saving with "Editable script" instead of "Binary".
Works for me with editable and I get your result when saved as binary.
My 2D view however shows an empty opening in both cases.
โ2008-01-18 08:12 PM
