artecon
Custom Window
Is there a way to make a window like the one in the attached picture?
Ive tried Variable Window, Variable Double Sash Window, Window with Sidelight, but there is no way to divide sidelight like in the attached picture.
Thanks!
4 Replies 4
Lingwisyer
Guru
If they are all the same, I would just model a custom window on the floor plan;
https://community.graphisoft.com/t5/Design-articles/How-to-create-Custom-Window/ta-p/303432
Ling.
ps. See links in my signature.
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
If a standard window does not do it you could create it with a curtain wall instead.
Or create your own custom window from slabs and save as a window object.
Or search in the window tool to see what is available in BIMComponents.
I found this.
I have not used it so can't say if it will do what you want or not, but it looks close.
Lingwisyer
Guru
Here's an old video by the creator of that object;
https://www.youtube.com/watch?v=HJLPn90GrFQ&ab_channel=HeimoMooslechner
BrunoH
Two simple windows assembly
ArchiCad 3.43 to 28
MacOS Monterey
