Custom light fixture
I have created a custom light fixture using Boolean operations. I have an error in the script: 'SPHERE_RAD' isn't a valid parameter name. THis appears for like 12 lines of code. Here is what is AC10 is telling me I need to fix: Is fixing it going to be more difficult then starting over do you think?
sprism_{2} "Zinc", "Zinc", "Zinc",
13, 0'-0.0000", 0'-0.0000", -1'-6.8431", 0'-0.0000", 1'-7.3616", 28.59498338374,
0'-0.0000", 0'-0.0000", -1'-6.8431", 0'-0.0000", 0'-0.0000", 28.59498338374,
0'-0.2500", 0'-0.0670", 79,
0'-0.1830", 0'-0.1830", 79,
0'-0.0670", 0'-0.2500", 79,
-0'-0.0670", 0'-0.2500", 79,
-0'-0.1830", 0'-0.1830", 79,
-0'-0.2500", 0'-0.0670", 79,
-0'-0.2500", -0'-0.0670", 79,
-0'-0.1830", -0'-0.1830", 79,
-0'-0.0670", -0'-0.2500", 79,
Frank Beister
Have a look at www.selfgdl.com. As far as I can see is missing your command the material information (the forth value of each edge after x,y and status) in the path definition.
