Cutting a Hole in a Slab
Is it possible to cut a hole in a slab, similar to the way a door/window cuts a hole in a wall?
I am trying to make a recessed object cut a hole into the ceiling slab which it is placed.
Thanks for the help.
9 REPLIES 9
Do you mean a "slab hole" GDL command?
Yes, exactly.
TomWaltz
You can cut a hole in the slab, using the basic slab pet palette then place an object into the opening, but there is no "slab opening" or "floor window" tool
Tom Waltz
Is there a GDL command to cut a hole in a slab? Similar to WALLNICHE or WALLHOLE?
TomWaltz
Nope.
Tom Waltz
Thanks anyway all!
try Solid element operations if you want your hole to follow your object around.
If I were in your situation I would do this:
Instead of using a slab, I would use a plane roof to built the ceiling... and then modify a skylight object... Maybe the wallhole command works in this object... Just a hint...
Aussie John
Yes, but…
Use the roof tool (0 degrees) and add a skylight type object
EDIT:
Sorry didnt read Brazza's post
Cheers John
[/size]
