D Hinged Gate 19 - Pivot Parameter
Tincan561
The object D Hinged Gate 19 does not seem to have a parameter for the pivot.
It is coded as pen 5, and unfortunately I need to change it.
I know how to open an object and save a revised version, however I am unable to locate which 2d Script or Parameter to change.
Thank you.
Archicad 26 Macbook Pro, Ventura 13.6.3
NCornia
Graphisoft Alumni
Graphisoft Alumni
Hi Tincan561,
Sorry for the inconvenience. I looked into the script of this object and it does not contain a parameter in the Parameters page of the script to control the pen of that particular element. And as I am not a GDL expert myself I will put this to the attention of the Library Team.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
David Maudlin
Hi Nicholas:
I tried to look at this issue, but when I opened the library part and went to the 2D View, the window was empty except for the Wall and opening. Is there a trick to getting the ArchiCAD Library Doors and Windows to show in this GDL window? This makes looking into these issues more feasible.
Thanks,
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
