DEFINE SYMBOL_FILL
Frank Beister
Has anyone successfully used the DEFINE SYMBOL_FILL-command? If I use it slavishly like in the manual I get a "need numeric parameter"-error in the section of the macro-call. Am I doing something wrong or is it a bug? I attach a simple (not working) example.
David Maudlin
F. Beister:
I have not used this command, but I see that you have a "get ( 8 )" as one of the parameters, but no "put" statement. When I substituted 8 numbers for the get ( 8 ), the error message went away.
DEFINE SYMBOL_FILL name 1, 1, 1, 1, 1, 1, 1, 1,
frequenzX, frequenzY, verschiebungX, verschiebungY,
winkel, skalierungX, skalierungY,
macroname PARAMETERS a=1.1, b=1.1, h=hoch
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Frank Beister
Thanks David. Seems to be the hint. I have extracted the demonstartion object out of a larger one, where I calculated the bitmap pattern out of an text array. I forgot to substitute this or the demo.
But I think, that it's a bug in AC:
name="Test"
frequenzX=1.5 : frequenzY=0.15
verschiebungX=1 : verschiebungY=0.1
winkel=0
skalierungX=1 : skalierungY=1
DEFINE SYMBOL_FILL name 1,1,1,1,1,1,1,1,
works.
name="Test"
winkel=0
put 1,1,1,1,1,1,1,1
DEFINE SYMBOL_FILL name get(8),
stops by reorting an error.
Thanks again.
