DEL TOP for CUTEND
JGoode
I was wondering if there was an equivalent of DEL TOP for CUTEND?
Thanks
ArchiCAD 23
Windows 10
JGoode
I've thought of a workaround for now using for...
			for j = 1 to 100
				CUTEND
			next j
ArchiCAD 23
Windows 10
The number of CUTENDs needs to match the number of CUTs (CUTPLANE, CUTPOLY, CUTSHAPE, etc.).
If they don't match I am pretty sure you will get error messages.
If you are unsure of the number of cuts being performed because of looping in your script, then you can create a counting variable that increases by one every time you have a CUT command.
i.e.
CUTPOLY .....
cut_count = cut_count + 1
CUTSHAPE .....
Then at the end you can say ...
for j = 1 to cut_count
       CUTEND
next j
This will only work if you want to end the cuts at the end of your script.
Sometimes you need to a particular cut straight after a particular command and then carry on with the script.
I guess in this case you could do a CUTEND and then reduce the count by one and then end the rest at the end of your script.
