rob2218
DOOR PANEL - HOW TO SHOW BOTHS FACES THE SAME WITH RAILS?
SEE ATTACHED.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
11 Replies 11
rob2218 wrote:
SEE ATTACHED.
. Cadimage doors show it both sides. You could make a custom door or door panel as well. But I would recommend acquiring the Cadimage doors and windows.
Stress Co_
Rob:
Changing the Fill pen or Fill type should do it.
(And if the materials are the same, for panels & rails,... create a duplicate of
the material with a different name, i.e. "copy")
Marc Corney, Architect
Red Canoe Architecture, P. A.
rob2218
I guess I wasn't clear on my door panel statement.
How can I get the styles and rails on door panel types which have them available in the Archicad 17 library to show up on "BOTh" faces of the door panel?
It appears that in elevation view,......the doors which have the available styles and rail frames only are showing up on ONE side of the door.
Also.....flipping the door to view the rectangular frame around the door doesn't work because that effect merely changes the swing direction of the door......
GS, Got any thoughts?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Stress Co_
No. I understood the question.
Try changing the values.
It worked for me in AC18.
rob2218
Changing the value of the "surfaces" makes both sides of the door object show the styles and rails? "WHATCHU TALKIN' bout Willis?"
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
Would love to acquire the CADImage suite......just can't justify to my employer a $600 add-on to make doors which should be showing both sides of the panel with styles and rails....
SenecaDesignLLC wrote:
rob2218 wrote:
SEE ATTACHED.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Stress Co_
Works for me in AC17. Elevation and 3D.
To restate: I change the material for the Door Panel's Fill Type and
I'm able to see the rail/panel lines in elevation (the side that didn't
work) and in 3D.
Are we using the same door?
D1 17, Standard 1 Panel
Regardless... I'd say it's a bug.
rob2218
dude...YOU da MAN!
I have no idea how in the world you figured out that by adjusting some OBSCURE fill pattern in a sub-parameter of this door object forces a change in the door panel to show the styles and rails?....KUDOS to you my friend. thanks.
Now....as long as we are on the subject of doors and their appearances....how would I go about changing the vectoral hatch pattern of the inside panel of that same door we are talking about separate from the styles and rails materials?
meaning...if I wanted the door panel to have, say a vertical 4" wide slats let's say...and the styles an rails to have, say a white paint color...then how would I change that?
work) and in 3D.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
see attached.
i>u
Edgewater, FL!
SOFTWARE VERSION:
