DOOR PANEL - HOW TO SHOW BOTHS FACES THE SAME WITH RAILS?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2014-10-31
07:11 PM
2023-05-24
10:50 AM
Rubia Torres
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-11-01 01:14 PM
rob2218 wrote:. Cadimage doors show it both sides. You could make a custom door or door panel as well. But I would recommend acquiring the Cadimage doors and windows.
SEE ATTACHED.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-11-01 03:16 PM
Changing the Fill pen or Fill type should do it.
(And if the materials are the same, for panels & rails,... create a duplicate of
the material with a different name, i.e. "copy")
Red Canoe Architecture, P. A.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-11-01 05:37 PM
How can I get the styles and rails on door panel types which have them available in the Archicad 17 library to show up on "BOTh" faces of the door panel?
It appears that in elevation view,......the doors which have the available styles and rail frames only are showing up on ONE side of the door.
Also.....flipping the door to view the rectangular frame around the door doesn't work because that effect merely changes the swing direction of the door......
GS, Got any thoughts?
i>u
Edgewater, FL!
SOFTWARE VERSION:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-11-01 05:59 PM
Try changing the values.
It worked for me in AC18.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-11-01 06:04 PM
i>u
Edgewater, FL!
SOFTWARE VERSION:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-11-01 06:11 PM
SenecaDesignLLC wrote:rob2218 wrote:. Cadimage doors show it both sides. You could make a custom door or door panel as well. But I would recommend acquiring the Cadimage doors and windows.
SEE ATTACHED.
i>u
Edgewater, FL!
SOFTWARE VERSION:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-11-01 06:30 PM
rob2218 wrote:Works for me in AC17. Elevation and 3D.
"WHATCHU TALKIN' bout Willis?"
To restate: I change the material for the Door Panel's Fill Type and
I'm able to see the rail/panel lines in elevation (the side that didn't
work) and in 3D.
Are we using the same door?
D1 17, Standard 1 Panel
Regardless... I'd say it's a bug.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-11-01 07:40 PM
I have no idea how in the world you figured out that by adjusting some OBSCURE fill pattern in a sub-parameter of this door object forces a change in the door panel to show the styles and rails?....KUDOS to you my friend. thanks.
Now....as long as we are on the subject of doors and their appearances....how would I go about changing the vectoral hatch pattern of the inside panel of that same door we are talking about separate from the styles and rails materials?
meaning...if I wanted the door panel to have, say a vertical 4" wide slats let's say...and the styles an rails to have, say a white paint color...then how would I change that?
Stress wrote:rob2218 wrote:Works for me in AC17. Elevation and 3D.
work) and in 3D.
i>u
Edgewater, FL!
SOFTWARE VERSION:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2014-11-01 07:44 PM
i>u
Edgewater, FL!
SOFTWARE VERSION:
