Define texture help
I have to script panels which have wood embossed surface and i need to be able to change the color of the wood.
I have used define texture and define material for the first one and hope to use define material based on to change the rgb color.
I can't figure out how texture must be to obtain such thing.
I've tried transparency, i've played with alpha channel but all fails.
Each little goal achieved in internal and lightworks engine don't shows up in opengl engine.
Can someone put me on the right direction?
Thanks
0 Replies 0
