Find the perfect object, manage libraries, create custom objects
Definitions of "Lamp" and "Whitewash" materials ?
I've bought "the GDL Cookbook 3" and there is a sample that I try to do.
The problem is that I do not have the 'Lamp' and 'Whitewash' materials in my material-list. I would like to see this sample with the right materials. Can someone help me with the definitions of this, or is it possible to import materials in another way ?
3 REPLIES 3
Are you using the INT version?
If so, you can start a new Project based on the ArchiCAD 12 Template.tpl file and I am sure these materials will be in it.
But I checked and I think Lamp is now called Glass-Lamp, and Whitewash is called Surf-White.
Thank you very much. I do have the materials you mention in my material list . Now I'll continue with my sample.
Now it looks like there are light in my lamp. Wow.
