Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Find the perfect object, manage libraries, create custom objects
Detail Marker Problem
Hello,
I am using detail markers to call out details in my projects. I am trying to find the "Detail Indicator NCS_11" but all I can find is "Detail Indicator 2_NCS 11." This is not the correct detail I am trying to achieve. There is one for Library 10, but I'm trying to use only Library 11, as I should be. There seem to be multiple problems with the 11 library, as I have noticed other things as well (interior elevation markers missing...). Does anyone know what is going on? Should I re-load the library, and if so, where can I get it as it says my library is already up to date?
1 REPLY 1
Djordje
Check the Archicad 10 library subset for Archicad 11, available on the update page.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
