Disabled People Models?
Does anyone know where I can get disabled people objects? More specifically I am doing an ADA residential addition and remodel and need a person in a wheelchair. The standard ArchiCAD library doesn't appear to contain any (I am using SE9). I may have missed something somewhere but I think these should be standard issue.
Thanks in advance for your help.
Gary Bley
13 Replies 13
I know I've used one in the past but I couldn't fine it in the SE library either. Perhaps it's in one of the older libraries...
I just searched my libraries and found "Man in Wheelchair 70.gsm". So if you have the ArchiCAD 7 library that will probably work. I believe there are also some in other libraries. Digital Architecture (AKA David Maudlin) also has one in the "People Library" and there is one (at least) in Objects Online.
Eduardo Rolon
check
www.objectsonline.com/customer/home.php
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Thank you both very much. Problem solved. It seems that GS should be including these people in the standard library. Designing for accessibility should be a common practice as I hope sustainability soon will be.
Gary Bley
ArcAngel
It was originally called "andrew_in_Wheelchair" and was part of the old "People and More" Library from around 1996
Carlo
AC4.5 - AC 25 (User since 1992)
Djordje
AFAIR it used to be on GDL Central, that is AFAIK now moved to Depository? Did not check, I admit.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Stress Co_
Here's a PDF view..... anyone know where to get this Library? I ... how do you say?.....ich spreche nicht Deutsches.
http://www.idc.ch/archicad/Download/PDF/zusatzbiblio/people_more.pdf
Marc Corney, Architect
Red Canoe Architecture, P. A.
Thomas Holm
I've got the People and More CD somewhere. If the pdf that Stress Co. uploaded is correct, it seems it was produced by the Swedish company Maccaddy which went bankrupt later, as did the LaserCad that bought it. Today's LaserCad (the Swedish Archicad distributor) is a reconstructed firm, and I don't know if they have the rights to this library now. Maybe Ben O'donnel knows? And perhaps they have some to sell, or are willing to upload it to the repository?
Stress Co_
I tried downloading from here:
Online Shop> ArchiCAD Bibliotheken> People and More
I think it's free.... but not knowing German... I couldn't complete the check out process.
There's no problem with your german
The Link is simply not working.
it is: file://///Serveridc/Abteilungen/Internet/www.archihelp.ch/public_html/download/bibliothekselemente.asp
if you shorten the link to www.archihelp.ch/public_html/download/bibliothekselemente.asp witch lead you to a "The page cannot be found"-Page...
