muzedesigns
Discover number of polygons per object?
Hello!
How can you work out the polygon count or number of polygons in particular objects?
I am exporting to Cinema 4D and having serious trouble rendering out animations - i would like to compare the poly count of an object I created in ArchiCAD to one I could buy that is C4D Native.
Thanks for your time!
Chrissy Avramidis
|| ArchiCAD Versions 7-22 ||
|| 27inch iMac Pro (2017) | macOS High Sierra 10.13.6 | Processor 3 GHz Xeon W | Memory 64GB 2666 MHz DDR4 | Graphics Radeon Pro Vega 64 16368 MB||
8 Replies 8
muzedesigns wrote:
Hello!
Select the object you want to check and then go to the WINDOW menu > PALETTES > POLYCOUNT
muzedesigns
Thank you for your reply.. I do not have that palette option.. the closest i get is 'element information' but if does not contain the poly count info.. i then searched 'poly count' in the archiCAD help and nothing came up.. has this feature been removed in later versions of ArchiCAD (AC11)?
Chrissy.
Chrissy Avramidis
Chrissy.
I forgot it is a "Goodie" so you will need to have it installed.
You can track down the goodies via the help menu.
Or this link should get you there.
http://www.graphisoft.com/support/archicad/downloads/goodies11/AUS.html
muzedesigns
Thanks Barry - that was really helpful and exactly what I was after..
You don't have any suggestions how I compare a Poly Count Value (2,999) to a Value of 'Faces' (8 193) or 'vertices' (10 255)?
Chrissy
Chrissy Avramidis
In 3D they are usually called, depending on the program, nodes or vertices (points - 1 dimensional), edges (lines - 2 dimensional) and polygons or faces (planes - 3 dimensional). So I think you should look at the number of FACES of the object.
muzedesigns
Oh OK - that makes sense.. ow do I find out the FACE values on ArchiCAD Objects?
Chrissy Avramidis
What is called FACE in another program is called Polygon in ArchiCAD. The PolyCount Add-On will tell you the Polygon number.
muzedesigns
Thank you for all your help Barry and Laszlonagy!! the ArchiCAD object wins!
Chrissy Avramidis
