We value your input!
Door 19 construction error
fuzzytnth3
I'm guessing whoever scripted the ArchiCAD 19 Door 19 (and it's brethren) has never made a door.
The Door Stiles should run the full height of the Door Leaf with the top and bottom rails fitted inbetween.
Whereas the Door 19 object has been scripted with the top and bottom rails going the full door width and the stiles fitted inbetween.
It's annoying when you use a timber grain fill on the surface material for the door leaf as it is very visible
To be fixed in AC20 perhaps?
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
Katalin Borszeki
Thank you for reporting this issue. It's been added to our database to be fixed with the ID #196064.
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
fuzzytnth3
Cheers thanks for letting me know
