Door Casing
Steve Jepson
I think this may be a problem with which library part I am using?
undefined
Jere
In the door settings, go to the "General Settings" tab. Change "Wall Closure" type to "Studwall with Siding" or "Brick Veneer." That'll fix it.
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
Steve Jepson
Thanks Jere, That will fix the trim but it causes another problem.
It moves the jamb to the outside of the wall and I need it on the inside.
I don't think I can move the jamb to the inside face of the all and still get the casing effect I need.
This is close as I can get and more accurate anyway.
