Door Centerline Removal
I am trying to remove the centerline that is associated with my door dimensions but it doesnt seem to want to go anywhere. Any suggestions on how I might do this? Should be simple, if it is possible at all... I just cant figure it out.
Thanks
Mike
ArchiCAD 8.1
1 Reply 1
I'm guessing that you're talking about what is shown in the attached: clear the checkbox to remove the centerline.
HTH,
