Door Definitions - Interior & Exterior
When placing a "D1 Entrance" door the swing side is considered the interior (which for us is never the case). If the door is Flipped, it is correct. If the "flipped" door is saved as a Favorite, the newly placed door STILL need to be flipped.
Either always remember to place the doors Swinging Out and Flip
OR
Change the door Parameters so that the "Interior Trim" is actually my to Exterior trim and "Exterior Trim" is actually my to Interior trim.
What are others recommending?
2 Replies 2
Under options, in the parameters section for the D1 entrance doors, you can choose whether the door opens in or opens out. Would that not help your situation?
I may have attempted to use this Option before and had forgotten about it, yet in the screen Shot you can see that the Swing Option was set to inside yet the Trim set to Inside shows on the Outside?
