Door Leaf Material
JGoode
When creating a custom door leaf, is it possible to be able to change the material in the door object?
Thanks
ArchiCAD 27
Windows 10
1 REPLY 1
Erwin Edel
In our local library this is not possible and as far as I know it is just a translation of Graphisoft parts in this regards.
I've set up a parameter in the custom leaf that I call in the 3D script to change material and if I have the same leaf used with different colours, I need to save out several versions.
I did make a 'wish' for the call statement to pick up the leaf surface parameter for the 'default' material of a saved object. We actually had this functionality in the local NL library for a while. It changed when they switched over to using the Graphisoft parts, I think.
It's not very difficult to map the leaf parameter from the door to the called custom leaf, but at the moment, the parameter is just not set up in the call statement.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
