Door Leafs missing
I don't think they are missing but new styles are ignored
Opened a model that was correct on laptop
On desktop the leafs do not show
And if I change the leafs - no change - just a flat panel or lo leaf - can't tell
Eric Milberger, Architect | Master Planner
1 REPLY 1
Check your Model View Options Settings.
The "3D and Section/Elevation" setting for Doors is probably not set to "Full", which is the reason why you see a simplified Door Leaf instead of a fully generated one.
