2015-02-05 09:08 PM - last edited on 2023-05-24 10:49 AM by Rubia Torres
2015-02-05 10:15 PM
2015-02-05 10:43 PM
2015-02-05 11:14 PM
2015-02-05 11:49 PM
2015-02-05 11:55 PM
2015-03-12 08:00 AM
DSquad96 wrote:Hi, I understand you perfectly - DSquad96 - the door should show the master id of the hotlink in it's marker...it has nothing to do with the zone... look at
I suppose my question though is:
If the Door's ID is already C213A, why does that not show in the marker?
2015-03-12 02:39 PM
2015-03-13 03:58 PM
matjashka wrote:The Master ID is a field that can be set separately for each placed instance of each Hotlinked Module. So the Full ID of elements in each instance of a Hotlink can be different.
(pardon my curiosity, but if a module is inserted on multiple floors - for example in zones 121, 221, 321, 421, etc. -, how do you determine which ID from the master file is the correct one to be shown in the module...? this is an arbitrary decision)
2015-03-13 04:24 PM
