Door Opening Lines in Projected Display?
Dear People,
I am trying to have door opening lines while the door is in "PROJECTED" display type. Yet Couldn't still.
I also tried, changing Model View Options form Document Menu to "full opened leaf" again no luck.
Is it possible to make door be dranw like projected and also have opening lines appear?
Does anyone know its why? Or what Am I missing?
And for one who wonders why I need that, "Symbolic" door display option is named as a weak type of drawn expression for this porject. That's all.
Thanks in advance
1 Solution
Lingwisyer
Guru
Could you just change the Level of Detail for the door in Symbolic display? Unless you are also wanting to see the door handle...
Go to post
1 Reply 1
Lingwisyer
Guru
