Door Trim
What code is needed to make door trim in the 3D Script that acts as a separate object from the door itself. I'm using the cprism_ command to make all the necessary parts for a door, and that works fine. When I use the cprism_ command or the tube command to make Exterior or interior trim for the door, the trim still show up in the width of the door. For example, if I make a 9'-0"x8'-0" garage door and want 4" trim to go around the door, when I add the 4" trim, the final width of the door shows up as 9'-8" total instead of the original 9'-0". How do I make the trim act 'separately' from the door itself?
Thanks in advance for any help.
Just a wild guess, since you haven't shown us your code, it might be
that you have redefined the values of A and B somewhere in the script. Which is something you should never do.
Peter Devlin
