Door/Window Marker in ALL inches ie 48"x96"
I want my door and window marker to show the size of the door or window in all inches.
To my knowledge, there is no way to do this, correct?
hoping someone can surprise me...I know I could use the FM Parameters and put the dimension in manually but I really don't like to do anything that underminds the automation and forces me to remember to do things manually.
Thanks
8 REPLIES 8
David Larrew
You would need to do a little GDL scripting within your D/W Marker.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Can you give me a push in the right direction"
ie......
1. Where can I find the marker?
2. How do I open & edit it?
I know how to open and edit objects, but I can't seem to find the dimension markers any where on my hard drive
Thanks
David Maudlin
Go to File > GDL Objects > Open Object by Subtype... then Drawing Symbol > Marker > Window-Door Marker and you will see this list of the currently loaded markers (both built-in and in the loaded libraries), choose the part you want to alter and click Open. Save As... a copy of this part for editing.
The formatting of the text for dimensions is handled with the Str (String Function), check the GDL Reference Guide for an explanation and examples.
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Stress Co_
Dan Kunschik created a set of Builder Dimensions (talked about here)
It would display All inches as 48 96 . Not sure if it works on AC9...
Marc Corney, Architect
Red Canoe Architecture, P. A.
HTH
What version are you in? I tried to do this on my MAC (I Just purchased one and I'm lost on how to workwith it) on version 11 and I can't find any individual objects in the place you told me to go.
It almost looks like version 11 has packaged everything into a single file and I cannot isolate individual objects.
I just put two bullets in my brain trying to convert from pc to mac and version 9 to 11 at the same time.
My head hurts.............
Dans not into responding to emails or PM's. I've tried to reach him for over a year with no success.
Hope he's ok............
I don't know if Open Object by Subtype is on that menu by default. It wasn't on mine, but I may have modified it. But I don't see it the Standard Commands WE scheme either. You might have to add it in the Work Environment.
The 11 library is all one file, a library container file, LCF. The other way of getting to individual markers would be to extract the LCF, which copies it to regular folders. You should find the Extract a Container command on the File -> Libraries and Objects Menu.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
David Maudlin
vincon2:
Following your signature, I based my reply on ArchiCAD 9, as James said, you may need to add the "Open Object by Subtype... " command to your Work Environment. This will give you access to all the library parts, some of them, like the Basic Door-Window Marker, are built into the application, so won't show up in an extracted .lcf file.
HTH
