Door/Window Sides Material
I have a stone wall that I am putting in custom gdl doors & windows. The sides of the Wallhole are showing as stone, but I want them to be white. Is there a way to programmatically change this wallhole side material? Would this be the built-in variable "ac_wallholematerial"?
Thanks in advance for any help.
3 Replies 3
you can always code your door or windows with some prisms of the white material near the frame.
One problem is it will be seen in lists.
Hope it helps
Make sure your WALLHOLE command uses the status code of "2".
Then you can set any material you want before the wall hole.
i.e.
material side_mat
WALLHOLE 4,2,
	-(a*0.5),0,15,
	(a*0.5),0,15,
	(a*0.5),b,15,
	(-a*0.5),b,15
For a wall that has different materials on the inside and outside you can match those on the side return by using 2 WALLNICHE commands instead of one WALLHOLE.
Set the material to the same as that for the inside and outside wall face.
i.e.
extend_niche = 0.1          !! this just ensures the niche extends outside the wall
m1=1	!!the polygon will create a visible edge upon entry into the body being cut
m2=1	!!depth - the lengthwise edge of the cutting form will be visible
m3=1	!!the polygon will create a visible edge upon exiting the body being cut
m4=0	!!outside - the bottom edge of the cutting form will be visible
m5=0	!!inside - the top edge of the cutting form will be visible
m7=0	!!controls the viewpoint dependent visibility of the lengthwise edge
MATERIAL WALL_MAT_B
WALLNICHE 4, 1, 1*0 + 2*1 + 8*0 + 16*0 + 32*0 + 64*0 + 128*0,
0, 0, 1, -K_-extend_niche,
	-(a*0.5),0,1*m1 + 2*m2 + 4*m3 + 8*m4 + 16*m5 + 64*m7,
	(a*0.5),b,1*m1 + 2*m2 + 4*m3 + 8*m4 + 16*m5 + 64*m7,
	(-a*0.5),b,1*m1 + 2*m2 + 4*m3 + 8*m4 + 16*m5 + 64*m7
MATERIAL WALL_MAT_A
0, 0, 1, C_-K_+extend_niche,
	(a*0.5,b,1*m1 + 2*m2 + 4*m3 + 8*m4 + 16*m5 + 64*m7,
	(-a*0.5,b,1*m1 + 2*m2 + 4*m3 + 8*m4 + 16*m5 + 64*m7
Thank you to both of you for responding.
