We value your input!
Door & Window Builder Install Problem
Dave Jochum
After installing the latest version of Door & Window Builder (3.5v11) every time I launch AC I get the error message shown in the attachment. Doing a FIND for the file comes up with nothing and re-installing doesn't help. Anyone know how to resolve this? T.I.A.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 13.5.2•AC 27 Silicon (latest build)
5 REPLIES 5
Aaron Bourgoin
Dave,
DWB installed into a folder that has sub-folders, one of which is a folder called Builder Notes. Once you point it at that folder, the message will go away.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-6000 USA
Rhino 8 Mac
MacOS 14.6.1
Dave Jochum
Aaron wrote:
Dave,
I should have mentioned in my post that that doesn't work. I've pointed to that folder several times but on the next log-in, the same message comes up. BTW, after cancelling the first message, another message follows that says "Extension Terminated", but DWB is available during that AC session and seems to work fine, though I haven't had the opportunity to build a window and use it in a project since upgrading DWB.
Dave Jochum
Aaron Bourgoin
Dave,
how about a clean install. There were problems with R10 and the building notes warning. R11 seemed to have solved that and so I wonder if there isn't some nasty point to "legacy" stuff. R11 did solve the problem here. Hope that's the simple solution to your problem.
It would sure be helpful if whoever is looking after the Theometric stuff would pipe in here. I don't know whether the silence over the transition or the anticipation of updates is hurting me more.....
Cabinet Builder 3.5 - where are you???????
Rhino 8 Mac
MacOS 14.6.1
Dave Jochum
Aaron wrote:
Dave,
That doesn't work for me either. Do you know if the installer places any files outside of the DWB folder? There is no documentation with the installer that tells, and no uninstall option, so I just trashed the one folder. Thanks for your help.
I've attached the second warning. Somebody could have done a spell check before release.
Dave Jochum
Aaron Bourgoin
I've sent an e-mail to CADImage Solutions asking for help with this installation problem as well as requesting some statement as to what's up with their acquisition of Theometric. It would be great to hear from them. Again.
Rhino 8 Mac
MacOS 14.6.1
