ā2004-11-24
01:19 AM
ā2023-05-24
12:49 PM
Rubia Torres
ā2004-11-24 07:01 AM
ā2004-11-24 09:10 AM
Aaron wrote:I should have mentioned in my post that that doesn't work. I've pointed to that folder several times but on the next log-in, the same message comes up. BTW, after cancelling the first message, another message follows that says "Extension Terminated", but DWB is available during that AC session and seems to work fine, though I haven't had the opportunity to build a window and use it in a project since upgrading DWB.
Dave,
DWB installed into a folder that has sub-folders, one of which is a folder called Builder Notes. Once you point it at that folder, the message will go away.
ā2004-11-24 09:34 AM
ā2004-11-24 05:25 PM
Aaron wrote:That doesn't work for me either. Do you know if the installer places any files outside of the DWB folder? There is no documentation with the installer that tells, and no uninstall option, so I just trashed the one folder. Thanks for your help.
Dave,
how about a clean install.
ā2004-11-24 06:17 PM
