Tom Krowka
Door & window markers
I have inserted as a module a floor plan into another AC drawing that is the site plan. I cannot turn off the door and window markers; the doors and windows are not on a separate layer and neither are the markers. The only way I can turn them off is by turning off the interior and exterior walls. That sort of defeats the purpose of the module on the site plan.
I don't want to have the site plan and the building on the same drawing because when I rotate the whole .pln with the site to fit on a sheet to plot, all the notes are reading in the wrong direction. That would mean I would have to insert all the notes on the wrong angle to read it right on the plotted sheet.
I'm digging myself a deep hole here.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
2 Replies 2
Tom,
Try under the display options - Show on plan, not Show with Dims (which I believe may be your culprit). Hope this helps.
Tom
Tom Krowka
That's the ticket.
Thanks
Thomas@wkarchwk.com
www.walshkrowka.com
