ā2006-02-17
03:11 PM
ā2023-05-26
11:40 AM
Rubia Torres
ā2006-02-19 09:11 PM
Mark wrote:This library is from GS and is the update/replacement for the standard library.
Would I talk to Graphisoft support to find this out? I'm not sure if this library was created by third party or?
ā2006-02-19 09:12 PM
Tom wrote:One would think so, but I haven't found it either. I assume that it is not available for wood doors (it's there as a check box for D1 Metal). This is a major pain and really should be added. I assume that there are some complications making it work in all circumstances (ie various wall types & geometries, trim conditions, etc.)
I'm sure there must be a setting for frame = thickness...
ā2006-02-19 09:15 PM
Karl wrote:Which doors have you tried? I can't find any setting for it in any of the wood doors. It also appears to be off by default in the metal doors. I am wondering how yours have been working "out of the box".
My frame depths match my wall depths out of the box on the doors and windows I've tried from SE9.
ā2006-02-19 09:28 PM
ā2006-02-19 09:37 PM
s2art wrote:This is a common approach, but is not used in the SE library. As a GDL programmer I prefer the check box. Resetting the parameter to 0 is sooo 90's.
For those with Door and Window Builder add-on, if you set frame thickness to 0 it will match wall thckness.
ā2006-02-19 09:50 PM
ā2006-02-19 11:35 PM
ā2006-02-20 01:40 AM
Mark wrote:Mark: what is the
Attached is a screen shot of two D.H. windows in a 12" thick wall.
ā2006-02-20 01:57 AM
ā2006-02-20 08:06 AM
