2006-02-17
03:11 PM
2023-05-26
11:40 AM
Rubia Torres
2006-02-22 09:45 PM
2006-02-22 09:52 PM
2006-02-22 09:55 PM
2006-02-22 10:00 PM
2006-02-22 10:11 PM
2006-02-22 10:16 PM
2006-02-23 05:08 PM
2006-02-23 05:38 PM
Jay wrote:I tried to reproduce this problem with the latest (AC10 beta) library but I couldn't . We have made some bug fixes lately so maybe this issue has already been correctedt. Just to make sure can you send me a sample file (with just one wall and one window)?
Seiss, Thank you for the 12-ste.... I mean 11-step program. I too wave found the SE lib very time consuming. I almost never use Brick Anywhere, but I was using similar settings for my Wood trimmed Windows. Except for Step 10. Using these step I was able to get a 1/2 Round Window to display without Errors, but the same setting cause a "Polygon is degenerated" Warning with the W1 Casement SE9. (See Attachment)
Problems with the Windows will be Shown in future Post as Attachments.
2006-02-23 05:47 PM
Jay wrote:The bottom overhang of the side trim can be adjusted on the casing tab page with the "Casing trim bottom overhang parameter". Do you use this option? Also note that for the brick molding you can set negative or positive offset on the very same tab page.
Exterior trim view at lower left corner of W! Casement
Sometimes the Side trim is extended lower than the Bottom trim, but not often. And in all cases, unless mitered, the Side trim at least runs to the Bottom of the bottom trim. Not the Bottom trim running through to the side trim.
Also Wall hole seems to be cut wider than Exterior side trim.This has been fixed in the latest version.
2006-02-23 05:55 PM
Jay wrote:Again I can't reproduce the error message in the AC10 version however I have found an other bug with the bottom brick moulding (that will be fixed). I'd appreciate if you could place a copy of this bugy half round window in the sample file which I asked for in my previous mail.
Same Exterior problem with the W Half Round Fix SE9.
I can live with this one the Warning about Polygon..... only happens the first time it is viewed in 3D window.
