Door and Window Marker Geometry
I cannot seem to get the door marker to show with a circle and be able to change the size of the circle like in AC 21. Where is that setting?
poco2013
Mentor
in the "Label Selection Settings" DBX:
In the Text Style Panel -- turn on 'Frame'
In the Symbol Label Custom Setting Panel:
Under : Label Geometry Tab
Set: frame shape
Gerry
1 REPLY 1
poco2013
Mentor
Set: frame shape
Gerry
