Door and window objects do not display all the details in 2D and 3D views, why?
The 2D view does not show me the drawing of the door opening.
The 3D view does not show me the detail of the door, fisted ....
See image c attached.
Thank you for your help !
Post moved.
Please do not post everything to 'Archicad+' unless it is a discussion about Archicad itself.
Please read the forum section descriptions to find a suitable place to post.
As with you other post about the objects, look in the Model View Options (MVO) for Level Of Details settings for doors and windows.
it works !
Indeed it was necessary to select the view (All 3D), then go in documentation / model view to pass it in execution. Do the same thing in 2D view.
Thanks again !
Remember if you are using the Project Map to view your model, then you manually set which MVO combination you are using.
But when using the View Map to view your model (and it is these views you will add to your layouts as drawings), the MVO combination being used is stored in the view settings.
So just amending the MVO combination will reset all of the views that currently use that combination.
In version 22 you just amend the MVO combination and that is it.
In earlier version you must 'Store As' to redefine the combination.
