Dani Baiana
Door and window settings Archicad 26
Hello everyone,
can you help me understand why I can't sett my Door and Windows settings? When I want to put my measures in Preview and positioning I can't change anything below 280 for width and 340 for height.
There are 2 screenshots showing what my problem is.
5 Replies 5
cuba
They just set the limit to 280mm x 340mm, probably because of certain accessories.  This is approximate size of a door for a small dog.
Apple M1 Max 32 GB
Latest AC
scottjm
Mentor
If you remove the frame, reveal and casing you can go down to 200W x 300H
Dani Baiana
It's not in mm it's in cm...it's very big! Here is expl.
Dani Baiana
Do you maybe know how to fix this, which I think is the problem?
cuba
Are you sure your working units are set to cm?
Options/project preferences/working units.
Apple M1 Max 32 GB
Latest AC
